Plug used typical phone plug 4 wires not six waswires available Amp sub combo sounds good not using it but fact it does not work reflects possible amp problems in near futurefuture
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
SOURCE: remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
SOURCE: Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
SOURCE: I recently purchased the mtx
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
