Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
A mixed number is a number composed of an integer (whole) number and a proper fraction, one that has a numerator less than the denominator. Example 2 1/3 =2+ 1/3. 2 is the integer part, and 1/3 is the proper fraction part.
Certain fractions can be simplified further because the numerator and denominator share a (common) factor. By cancelling the common factor in the numerator with the factor in the denominator,
one gets a fraction with smaller numerator and denominator.
For example the percentage you provide 0.15% can be converted to 15/10000.
Since 15 and 1000 are both multiples of 5, the number 5 is a common factor in both. 15=5*3, and 10000=5*2000
Cancel the two 5 (simplifying by 5) in numerator and denominator leaves 3/2000. Thus
0.15%= 0.15/100=0.0015=3/200
I hope that this makes sense to you.
First, is this a stand-type mixer? If so, have you removed the mixer head from the stand? The model # may be found there under the hinge on the mixer head. Second, if you still can't find a model #, why not Google images of B&D Multi-Mix units? It would probably help to put the model year in the search description, such as 1983 B&D Multi-Mix mixer. Once you find the matching image online, you should be able to find a model number.
The opposite of any number (be it integer, rational, or real) is the same number preceded by the negative sign.
Example : the opposite of a is -a (read it a negative a)
opposite of (-b) is -(-b)=b
A rational number is a number that can be written as a fraction. You should note that the set of rational numbers contains the set of all integers .
The opposite of 15/37 is -(15/37) which is equivalent to (-15)/37 and 15/(-37).
