Cell Phones Logo
A
Anonymous Posted on Mar 03, 2015
Where is the dialling code 01535 for ? - Cell Phones
drvalentine
Level 3:
Master:
  • Cell Phones Master 876 Answers
  • Posted on Mar 03, 2015
drvalentine
Cell Phones Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255252
Points
4299
Keighley, West Yorkshire
I have a snom 320 dialling out takes long time for connection
I guess this is a SIP phone , try dialling the number then add # at the end, a SIP phone does not know when you have finished dialling unlike a landline so # complets the dialling for you
I forget my code to reset the setting of my phone E63
Careful, it will erase your personal data on the phone.
You can try to restore to factory settings by dialling *#7780#
or you can
Reformat your phone by dialling *#7370#
or you can go to your local diller to reflash the phone
I have a HP j6450 unit and I have no problem faxing to numbers outside my area code, however each time I try to fax to a local number I get a communication error.
If you are doing this an the error is appearing then try removing the area code. Alternatively if you are not dialling the local number with an area code try adding the area code to the number. If that fails then try dialling the number with a telephone plugged into the Telco socket of the machine or directly in to the Telco wall socket to see if it responds to a local only number. If you continue to have problems then contact your local Telco supplier to sort out your problem.
International dialling codes
After dialing 011, the 3 digit code for Lithuania is 370. Dialing 011+370+(phone number) should work. Add 2 0's to the370 if a 5 digit couintry code is necessary. Below is a link to help with interational calling. All the best!
Greg
http://www.q7c.com/travel/telephone.htm
1helpful
How do you save numbers for one touch dialling?
Press PROG the button and dial 2 + 9 + the number and STORE.
If your outside line access code is something different, insert it instead of "9".
carl
Dialling problem in Nokia N 73 mobile
remove memory card / format the phone with*#7370#12345(or the lock code) /try it if it good the memory card is having a virus so you can format it or scan it on th pc
2answers
My nokia 6080 is auto dialling
the most popular,common and usolved problem.........check in nokia care if possible
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
