Here please take a look at this video and see if it helps. Thank you! Reset your Xbox 360 Settings Parent Controls NEW DASH Dec 2011
SOURCE: xbox 360 family timer
Try Unplugging it for an hour or so (like how power outages ask you to set up your console) and ask him if he knows it...
or de attaching the HDD :) it's removable you know!
so much power for a little kid :(
SOURCE: xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
SOURCE: family timer..forgot the code to
Hello.
There is a little insider trick to disable it:
Go to Settings, Highlight Parental Control, When the screen pops up
that says Enter Pass Code press: X, Y, Left Trigger, X. You'll be taken
to the parental controls screen where you can disable the passcode
previously entered.
I hope this helps :)
Kind Regards,
[email protected]
SOURCE: Forgot password to unlock family settings on xbox 360?
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings
Console settings
Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
