ZEEPAD 7 inch Android 2.2 Tablet Logo
A
Anonymous Posted on Mar 03, 2015
Change the time zone to CST - it is stuck on GMT
ka4iup
Level 3:
  • ZEEPAD Master 4,062 Answers
  • Posted on Mar 03, 2015
ka4iup
ZEEPAD Master
Level 3:
Answers
4062
Questions
0
Helped
1095353
Points
51404
Go into your settings, system date & time. Ensure the Automatic date and time is checked, along with Automatic time zone.
You can also make adjustments to time and date formats.
Back out, and restart your tablet to see if this works.
Date\time is a software function. Check to make sure you have the latest software version uploaded.
How to set time on Kindle Devices?
You chose a Time Zone setting when you first set up your Kindle Fire. Your Kindle Fire uses the date and time setting to display the time in the Status bar, and also to work with other apps, such as a third-party calendar, for example. If you tap Date and Time in Settings, you see four options:
  • Automatic: If you want Kindle Fire to control the date and time based on your location, tap to turn this feature On. If you'd rather set the time manually, tap to turn this Off.
  • Set Time: To manually set the time, after you turn the Automatic option Off, tap the arrow on the right of this setting to display additional settings. Tap the + (plus sign) and - (minus sign) buttons to change the time, and then tap Save.
  • Set Date: Tap the arrow to the right of Set Date and then tap the + (plus sign) and - (minus sign) buttons to set the date you want, and then tap Save.
  • Select Time Zone: Tap the arrow to the right of this setting to change your time zone.
  • The Set Time settings become available only if you first turn the Automatic option to Off.
Hello. I have bush Spira 10inch tablet. I can't change the time zone from GMT+8hrs China time. It's visible but not highlighted as other options in the same menu. Any help would be great. Peter
Hey there maybe a 'automatic timezone' option enabled under the date and time settings. See if that's there and if so untick it and you should be able to define the time zone.
How do i change the time on my kindle?
  1. Swipe down from the top of the screen and then tap Settings.
  2. Tap Device Options, and then tap Date & Time.
  3. If Automatic Time Zone is turned On, your device will use a Wi-Fi or Mobile network (if available for the device) to determine the time zone.
How do i change the time zone on my rca 7 voyager?
Touch the "settings" icon, go down to the "System" area, and touch the "Date and Time" icon : you can either set the time zone to automatic (rely on the network), or immediately manually change the settings time, and time zone.
How to change time
settings/more/time and date/untick the box that says "automatic time zone" then "choose your time zone " will be green so you can pick your zone and change the time
How do i reset the time zone to CST?
I would look in the settings and then time to change this option.
How do i change the date
1.Go to settings app.
2.go to general,and swipe down.
3.you will find ,Date and time option.
4.go to date and time and select your time zone.
if the time is wrong, touch on the time given below the time zone and change the time according to you.
I hope it helps you.
thanking you
1helpful
How to change clock on a kindle fire to british summer time
Step 1: Pull Down upper Status Bar - More +
Step 2: Select Date and Time
Step 3: Select Change Timezone
Step 4: Change to your preferred Timezone (British Summer Time is +1 GMT)
2helpful
2answers
How do I set my clock to eastern standard time on my kindle fire ?
On the home page, tap the gear icon at the top. Tap "More...". Tap "Date & Time". Tap "Select Time Zone". Scroll if necessary and tap "Eastern Time GMT-5:00".
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
