Re: how do i unlock tcl tv model L32D10P without a...
Rca universal remote model RCR6473R WORKS TO UNLOCK TV THROUGH TV MENU OPTIONS ONLY AFTER U PROGRAM IT TO WORK ON THE TV....USE THE CODE IN THE MANUAL..THERE ARE MORE THAN THREE CODES AVAILABLE FOR TCL TVS
RCA UNIVERSAL REMOTE Code 12434 worked on my Tcl L32D10P MODEL
AIM REMOTE AT TV..PRESS MENU....GO TO SETUP. PRESS UP OR DOWN ARROW KEYS TO MOVE ...PRESS LEFT ARROW KEY TO SELECT CHILD LOCK ..OFF. . Rca universal remote model RCR6473R WORKS TO UNLOCK TV THROUGH TV MENU OPTIONS ONLY AFTER U PROGRAM IT TO WORK ON THE TV....USE THE CODE IN THE MANUAL..THERE ARE MORE THAN THREE CODES AVAILABLE FOR TCL TVS
U cannot unlock tv without remote..tried but failed...thats what a child lock does...
AIM REMOTE AT TV..PRESS MENU....GO TO SETUP. PRESS UP OR DOWN ARROW KEYS TO MOVE ...PRESS LEFT ARROW KEY TO SELECT CHILD LOCK ..OFF. . U cannot unlock tv without remote..tried but failed...thats what a child lock does...
You can't post conmments that contain an email address.
Go to Google, and type in, 'how to disable child lock for TV model #' (type in the model of your TV); or you may be able to utilize the buttons directly on the TV that would allow you to access the menu that would display the option to disable the child lock function.
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are: Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you.
1.Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked
2.Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked
3.Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set
and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now,
if desired, you can change the settings on the V-chip by going to the MENU
and going to PARENTAL CONTROLS, or on some sets, going to MENU and then
going to TV SETUP, then to V-CHIP SET.
To enter service mode on a TCL 21F5 model TV, you will need to follow these steps:
Turn off the TV using the remote control or the power button on the TV.
Press and hold the "Menu" button on the TV.
While holding the "Menu" button, press the power button to turn on the TV.
Release the "Menu" button when the service menu appears on the screen.
Please note that making changes to the service menu can cause permanent damage to your TV if done incorrectly. It is recommended that you only make changes to the service menu if you are familiar with the settings and have proper knowledge of the TV's inner workings.
Also, It's better to check the manual or contact the TCL customer service for more details.
Hello
Without orginal remote control, it will be very difficult to unlock your RCA tv. If you can gather a original remote from your friends or realatives who own the same model of tv, just borrow from them and try the following methods. One amoung them will surely unlock your RCA.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. OK.
Hello
It is very difficult to unlock the FPA lock of RCA, without it original remote control. Just try to get it from anyone amoung your friends or relatives; just to open the FPA lock. You can use it after that, with the help of any other univrsal remote control. To open the FPA lock, do one amoung the following till you get the correct process for your TV.
Without its remote it will be difficult to unlock it. Just try to get its remote control by contacting RCA authorised service center or any other way. Universal remote controls will not activate the following said proceedings.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
