Question about Pride Mobility Products Hurricane PMV 4-Wheel w/55AH Batteries & Charger + Flat Free Tires - Color Viper Blue - Gray Fabric Seat
Where can i get brushes for pride hurricane in uk
Brushes for motor 3/8 1/4 1&3/8 long
    Sergeant:
  • 313 Answers
I would contact pride or a service centre as if you put the wrong grade of brush in the motor you can damage the comm and motor.
The motors are not cheap.
Posted on Jun 17, 2015
SOURCE:
Can cheap brushes cuase them to burn out
hi Frederick, sadly so , there are some really bad very low carbon content brushes coming from china, beware ,they will melt inside
Regards
Rob
Oct 11, 2015 | Healthline Pride Jazzy Select Elite...
Moter runs good but brushes burn out even when not under load
Next time you use it, have an amperage meter connected to check for the draw of motor. Excessive draw caused by faulty motor can be responsible for the issue.
Sep 20, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Shoud light red light flash behind charge indicater when switched on on hurricane
hi, is this still a issue, this is a fault ....
Regards
Rob
www.gewizrepairs.co.uk
Mar 12, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
One brush wire and spring breaks up
hi ,there could be a issue with commutator on the motor but make sure the brushes are a good quantity .... and the right ones..
Regards
Rob
Mar 12, 2015 | Pride Health & Beauty
Speed control on Pride Hurricane
hi, the speed control could be faulty, see if you can spray some Wd40 or contact cleaner in the gap and see if that improves things...is it the one with the snail , rabbit speed sign ?
one bar on the indicator does imply low battery power ...is it flashing ? if it is then that's a fault condition
Regards
Rob
Dec 23, 2014 | Pride Mobility Products Hurricane PMV...
Scooter shudders when starting and after stopping
hi, now firstly you need to check all connections fitting all plug connectors, remove one battery lead before proceeding so you don#t accidentally short something ... Now having done that you need to make sure the break is not losing power otherwords coming on, Check the brushes and let me know how you get on ...
Regards
Rob
Mar 07, 2014 | Pride Hurricane 4 Wheel Personal Mobility...
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
The scooter runs but super slow, I purchased two brand new batteries but it continues with the same problem.
hi,
Is there any change speed when you change from 4mph to 8mph ?
if not first check the controller under the seat, normally a black box, make sure that all connection onto the controller are clean and tight,
Check the motor brushes, undo the screw caps carefully,these can be brittle , remove the brushes clean , make sure the brushes move freely within the motor,
Check the brake on the side the motor, this normally has a freewheel attached to it,
Remove the brake unit but do not disconnect the two wires, and test again is the brake clicking when you power away, if not it's not releasing hence the slow speed, check the brake for open or shorted connection.
Regards
GeWiz.
Feb 05, 2010 | Motorcycles
Wiring has been disconnected need to rewire pride hurricane pmv scoote. Need service manual or wiring diagram.
Hello, If you need any manuals or wiring diagrams go to;
http://www.pridemobility.co.uk/ipb/
Username : pride
Password : access
Hope this helps...
Jan 26, 2010 | Hurricane Health & Beauty
Pride Mobility Products Hurricane PMV 4-Wheel w/55AH Batteries & Charger + Flat Free Tires - Color Viper Blue - Gray Fabric Seat Logo
151 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
