RVs Logo
Nora moss Posted on Feb 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1971 Alaskan pop up camper not over cab. I just purchesed it and non of the lights or anything work were would I locate the fuse box or junction box. It's on a 76 Cheyenne 1ton with a 454. Would the fuse box be in the truck or camper and were I've searched everywhere. Thanks.
Greg Scott
Level 2:
Novelist:
  • Expert 116 Answers
  • Posted on Feb 17, 2018
Greg Scott
Expert
Level 2:
Novelist:
Answers
116
Questions
Helped
41107
Points
377
Finding information on something that old is difficult but what you would have to do is look for a kick panel or false wall panel being held on by some wood screws. For the unit you have, most likely along the floor. Most I have seen with more modern campers would be near a sink, fridge or bed. If yours has a take that turns into a bed, try checking for a panel under the cushions or along the footboards under that area. Use a good LED flashlight for best visibility. A hint about access panels, if the screw head is an unusual style or square button look, most likely it wasn't meant to be accessible where screws with the typical #2 Phillips or cross-tip are there for general access at any time. Alaskan Campers
This link may also get you in contact with a manufacturer rep to give you specific details for your unit.
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Mar 11, 2009
SOURCE: fuse box diagram 1984 F-150
I regularly use the local library. They have repair manuals that you can check out. Also have electrical wiring diagram books for foreign and domestic that you can make a copy of to take home.
Anonymous
  • 3 Answers
  • Posted on Apr 03, 2009
SOURCE: pop fuse. need location of fuse box.
have you looked under steering wheel dash, also look in the glove box, and under the hood
Anonymous
  • 1489 Answers
  • Posted on Apr 29, 2009
SOURCE: Need to find fuse box inside cab to replace brake light fuse. Brakes don't light up when depressed.
Most fuse boxes are on or near the kick panel (left side of vehicle) under the steering wheel. Some (additional) fuse boxes are under the hood,
Anonymous
  • Posted on Jun 27, 2009
SOURCE: 2006 GMC Sierra 2500HD 4WD trailer light connection fuse blown?
under the hood on drivers side right behind the battery. Will be marked trailer light left sand right.
Anonymous
  • 578 Answers
  • Posted on Jul 01, 2009
SOURCE: 1996 Jaguar XJ6 - fuse box locations
check your fuses and module that control those function on the vehicle
2answers
My 1996 Komfort Fifth Wheel Camper slide out is not working. Where are the fuses please.
Question edited for clarity. Komfort with K.
Question moved from Heating and Cooling to RV.
This page says it has the manual.
https://inacreta.tistory.com/3
Fuses and where to find them.
https://www.google.com/search?q=1996+komfort+5th+wheel+fuses
Mar 18, 2022 • RVs
1helpful
What is the amperage for a 2009 Fleetwood Westlake Destiny?
Pop up campers are going to either be a 20A or 30A. If the cord on the camper looks like a standard house plug, it is 20A. If it is a larger, round connector, this will a 30A plug. The good thing about these various plugs is that they will only fit in the right connectors on the electrical pole at your campsite. So just plug it in where it fits. If you need to replace the cord, look at your campers fuse panel and see what the main fuse is rated for.
Jun 27, 2019 • RVs
Where is breaker box on 2000viking pop up
Many of the pop up campers will have the breaker box under a seat for the dinette. You will most likely have to use a screw driver to remove a panel. The screws will either be a Philips or S2 bit, check any wood panels inside and under the dinette seat for those screws. Worst case scenario, it may be located behind an outside panel, which typically is not done with modern designs.
Apr 14, 2017 • RVs
2answers
Location of Power Converter for 2009 Jayco 5th wheel camper?
It could be part of the DC fuse panel if there is a metal access cover door on it. Otherwise it will be near the battery.
3answers
Hot water heater went out. Can't relight
check that there is gas in the bottle , the tap is on
check that there is power to the relight system
1helpful
3answers
Why wont my rv thke a charge
i am asssuming that you are talking about your coach battery bank.are they 12 volt or 6 volt battery system. the arc is a short. check polarity. can you charge the batteries with an external battery charger? if so. then need to check converter output from your mian power panel. there are a few other things to check. need more specifics. and you need to have a volt meter handy.
Jun 21, 2014 • RVs
Location of manual overide slide
Mine is located underneath of the slide. If you lol through the back wheelwell you should see a black rod. My camper came with a manual crank rod. Not really sure if you could use anything else...it's a lot of cranking
2answers
Step light wiring diagram
You should have a separate fuse box for the 12 volt supply in your camper. It is usually next to or close to the breaker box. I am betting you have a blown fuse and nothing more than that.
Top RVs Experts
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a RVs Expert? Answer questions, earn points and help others
