Spark Plugs BR4HS  Plug 10/BX #3322 Logo
A
Anonymous Posted on Mar 03, 2015
What is the gap for my 98 sapphir futura spaek plugs
Lloyd Gardinerjr
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Mar 03, 2015
Lloyd Gardinerjr
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
4462
Points
77
2answers
1996 Yamaha YFM80 Badger. Spark Plug gap setting please
Edited text for clarity, make and model. Moved category to Yamaha.
Here is your manual and the spark plug gap setting.
Spark Plug Inspection - Yamaha BADGER YFM80N Owner's ...
https://www.manualslib.com > ... > Owner's manual
Yamaha BADGER YFM80N Manual Online: Spark Plug Inspection. The spark plug is an important engine compo- nent and is easy to inspect. The condition of the ... 96 · 97 · 98 · 99 · 100 · 101 · 102 · 103 · 104 · 105 · 106 · 107 · 108 · 109 · 110 · 111 · 112 · 113 ... electrode gap
2helpful
2answers
Got Bosch HR7DCX+ spark plugs for my 98 VS Supercharged V6 Statesman, what is the correct Gap size?
I can't tell you the correct gap but I thought I would mention it is best to use the gap the plug manufacturer suggests rather than the vehicle manufacturer. Sometimes they are different.
You will probably find a Bosch spark plug application catalogue on the net and this should provide the gap specification.
Spark plug gap setting for a 98 range rover
what have you replaced with your tune up? should change plugs and plug wires, as well as the fuel filter, and air filter. the plugs should be set to factory spec.. be absolutely sure you've got the correct wires going to the correct plugs. the coil packs are a pain to get to but if all else fails, it may be time to replace them.
2helpful
What is the gap for 98 chevy cavalier?
The spark plug gap is .050". Hope this helped and best wishes.
1helpful
Cant find the spaek plugs on a 2000 toyota corolla
on some cars you need to remove a plastic engine cover first.  And some cars have individual coils that sit on top of the spark plugs.  You thus need to remove these small coils to get to the spark plugs.
CE 98 lancer
the gap should be gaped at 30 to 35 personally I would gap at 30 so it will burn hotter and give more boost with out burning a hole in your pistons
Top Ngk Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
