Dell 1210S Projector Logo
A
Anonymous Posted on Mar 03, 2015
DELL .how do i rotate the sreen 180 degrees
How do i rotate the sreen 180 degrees it is on the roof
  • Official Brand Answer 560 Answers
  • Posted on Mar 03, 2015
DellCares
Level 0:
Answers
560
Questions
0
Helped
101945
Points
1292
Anonymous,
You should be able to press CNTR+ALT+Down Arrow or Up Arrow on the keyboard to rotate the screens image. You may also go into the projectors main menu to adjust. At the link below is the online manual for the 1210s projector.
http://dell.to/1zEbfMW
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Rotate screen
There are many ways.
With Intel HD Graphics Control Panel:
Rotate to 0 Degree: <Ctrl><Alt>Up arrow
Rotate to 90 Degree: <Ctrl><Alt>Left arrow
Rotate to 180 Degree: <Ctrl><Alt>Down arrow
Rotate to 270 Degree: <Ctrl><Alt>Right arrow
You can enter this Hot Keys panel by pressing:
<Ctrl><Alt>F6
Or right click on the desktop you will find:
Graphic Option. Click on it and in the expanded balloon,
Click "Rotation"
On monitor menu. This, I have no information. Couldn't find it on my Dell E2011H menu.
Hope this helps.
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
2helpful
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
How do u fix a web cam from showing yourself upside down
it is one of your settings, it will ask you to rotate, just rotate 180 degrees
18helpful
2answers
HOW CAN I ROTATE MY WEBCAM FOR ASUS K40IN
my webcam is erect.how can i rotate this problem?
20helpful
3answers
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
3helpful
Image on Dell 4700 Monitor has rotated 180 degrees
This should be a very fast fix.
First try pushing the Shift and Home key at the same time.
If that didn't do it,
Right click on the desktop,Click graphic properties,Click display settings,Uncheck the box "Enable rotation" and click ok.
2answers
Rotation of desktop
Flipped monitor display in Windows. Third-party software utilities such as the NVIDIA Settings have the ability to flip or rotate a monitor's display 0, 90, 180, and/or 270 degrees
Good Luck, Please dont for get to Vote/Thank You.
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
