Microwave Ovens Logo
A
Anonymous Posted on Mar 03, 2015
How can sound be muted on ffcmo934ls a Frigidaire microwave oven?
  • Official Brand Answer 2,267 Answers
  • Posted on Mar 06, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289350
Points
2557
I appreciate your inquiry, friend!
From what you have described you would like to mute the sound on your Frigidaire microwave, FFCM0934LS. I have researched your microwave and I was unable to any instructions on how to mute your sound. Unfortunately you are unable to perform that operation on your microwave. I hope this is helpful information. -Matt
How do i mute a panasonic NN-ST67JS microwave
I don't think you can. I see no sound button. Nor is there a code in the user manual suggesting such. At the bottom of page 12 in the user manual, there is a short description of what all the beeping is about. When a pad is pressed correctly, a beep sound will be heard. If a pad is pressed and no beep is heard,
the unit does not or cannot accept the instruction. The oven will beep twice between programmed
stages. At the end of any complete programme, the oven will beep ?ve times.
I don't think you will find the answer in the following: https://soundproofnation.com/how-to-mute-microwave/
Some microwaves have a sound button. Others may off the sound by pressing 0 or 1 a couple of times. Some have controls that put on a child lock, making the pad inaccessible, thus no beeps! If is another way to mute the sound in yours, a Panasonic tech would have to tell you. You might try their support. I just don't think there is that opton in your machine. https://www.manua.ls/panasonic/inverter-nn-st67js/manual?p=12
https://na.panasonic.com/us/support
Frigidaire pleb27m9ecd built in oven/microwave. The oven works fine. The plug on the oven that microwave plugs into is not working.
It sounds like you may have an issue with the plug that connects the microwave portion of your Frigidaire PLEB27M9ECD built-in oven/microwave to the electrical supply.
Here are a few things you can try:
  1. Check the power supply: Make sure that the oven/microwave is properly plugged into a working outlet and that the circuit breaker is not tripped.
  2. Inspect the plug: Look for any visible damage on the plug and make sure that the connections are secure.
  3. Check the wiring: Make sure that the wiring inside the oven/microwave is not damaged or loose.
  4. Test the outlet: Using a multimeter, test the outlet to see if it's providing power.
  5. Test the microwave: If you have access to a known good microwave, you can test the plug by plugging it into the known good microwave and see if it works.
If none of these solutions work, it's likely that there is an issue with the electronic control board or the plug itself, which will require professional repair.
It's best to contact the manufacturer or a professional technician for repair. They will be able to diagnose the issue more accurately and repair it.
My Underlight on my Frigidaire Microwave does not turn off
Hello Michael Fiedler, thank you for your post!
I understand that the light under your Frigidaire microwave will not turn off. Sounds like it could be a possible issue within the switch or receptacle. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. I hope this is helpful. -Matt
I started up oven and it made two popping sounds. now fan lights turntable still work but not heating also sounds different then before.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
2helpful
Frigidaire PLMB209DCB 1200W Microwave. Mfg 2005. Started sparking and loud popping. Scorched cardboard covering. Worth looking at to repair?
No, Your better off buying a new one. Sounds like the Magnetron is acting up and that is the most important and dangerous piece of hardware in the Microwave.
My 3 year old frigidaire microwave made a loud pop and stopped heating. Everything else works. It also now makes a loud humming sound while running.
heatman101 ][
\=-0-]
1helpful
Microwave is 6 monthes old. will run table will turn but not heating properly hearing strange sound and smell.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Hi. My Frigidaire Microwave does not turn nor does it give any sound that its working. You can see the word COOK but nothing is happening.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Frigidaire microwave not heating
Basic Microwave Oven TroubleshootingTips
heatman101=--=-=
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
