The start button doesn't seem to work. If I unplug the dryer and plug it back in the lights will go on the front panel. I press the button and I hear a beep. Then all the lights go off and nothing happens. Is the start button bad?
Try putting a light in the plug with the dryer and try again, if it dimes or goes out you have an electrical problem.
Maytag Neptune MDG5500AW Repair Manual
Maytag Neptune Gas Dryer MDG5500AWW Parts
Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
