Epson WorkForce WF-3640 Wireless Color All-in-One Inkjet Printer Logo
A
Anonymous Posted on Mar 02, 2015
It says paper size does not match the paper source setting, Print on Letter No Yes Remind later
What is it saysing and how do I correct it
Brett Duxbury
Level 3:
  • Epson Master 4,352 Answers
  • Posted on Mar 03, 2015
Brett Duxbury
Epson Master
Level 3:
Answers
4352
Questions
0
Helped
1120030
Points
13423
Check paper tray it might have a movable plastic thing that sets the paper size . Check printer properties on settings - printers - Epson Workforce printer properties. Check software you are printing from that it has page setup and printer setup paper size set correctly
Load try1 plain letter error on display screen appears on lexmark e342n
If printer is connected to a network, type the printer IP address into the address field of your Web browser. Click on Configuration and select on paper menu and make you have the correct settings. Make sure you selected the correct paper source and paper type.
Make sure on your application, the print settings matches with the printer. Check the print settings of the application that you are using. For example if you are using Microsoft Word, you need to click on print and click the properties button and go to the paper tab.
From the Paper Tab window you can modify the Input options like paper size and the source (paper tray). You may click on the drop down and select "Automatically select" for paper tray and select "Use printer settings on paper type and then click OK.
For further assistance, please contact Lexmark Technical Support.
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
I have a hp photosmart c4280 and whenever i print it says margins are incorrect. how do i set them correctly so i can print documents.
Check the paper size at the printer properties on control panel.
You may be trying to print an A4 document to a printer configured to print on Letter size paper.
The document paper size should match the printer's paper size deffinition.
12helpful
2answers
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
10helpful
4answers
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
1helpful
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
1helpful
3answers
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
2helpful
Machine telling me wrong paper size i have reset and reloaded but not working
Check the guides in the paper tray to make sure they match up to the proper position for your paper size. If for instance the paper tray is set to A1 by accident and you are using letter paper, then you request to print on letter sized paper the printer will think it doesn't have letter paper available and will ask for some. The position of the guides in the paper tray are what tells the printer what size paper is in that tray. Otherwise your paper settings in the paper meny are wrong as this can override the paper tray settings, check them to make sure they match the paper size in the trays also.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
