Video Cameras Logo
g
gene dillon sr Posted on Mar 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a jvc camcorder model gr-d350u that will not come out of safeguard mode
Brian Manuel
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 189 Answers
  • Posted on Mar 03, 2015
Brian Manuel
Expert
Level 2:
New Friend:
Cheetah:
Answers
189
Questions
0
Helped
47966
Points
490
Not sure , do you mean safe mode ?
1helpful
Jvc gr-d350u. Constant E06 code with either battery or power adapter
if the screen keeps showing e06 device is in safeguard mode """"please remove or reattach the battery""""" If the error continues, please understand that it is a FAULTY BATTERY. This error is very common and results when the battery life has been changed or altered due to time elapsing. There is not a lot that can be done except to request a new battery. I performed more research on this and found that an equivilent may be purchased directly from jvc.com for a fraction of the costs then replacing the entire unit.
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
2answers
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
3helpful
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
3helpful
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
2helpful
E03 safeguard mode
look for a tiny pinhole and insert a pin while powered up to reset
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
