Try turning off power off at socket for about 5 seconds, everything turn on activate bl,ton speaksoumdbar1st turn b4 TV turn rest,s thing s might work !??
I've noticed that a lot of times people will confuse a smart tv's ability to be wireless as opposed to Bluetooth capability. If it does have an input of 3.5 there are Bluetooth adapters available to make it blue tooth capable. Please keep in mind to purchase a good one and they must also be charged via micro usb before use
If your TV is bluetooth enabled, yes the same as your phone or other device.
If your TV is not bluetooth enabled, yes, but only with the auxiliary cable that came with your PBT 3001. The back of your TV should have a coaxial audio out (a solitary orange audio output). Depending on your model TV, you may have to get an adapter to be able to use this output.
http://www.southerntelecom.com/polariodsupport/downloads/PBT3001_battery.pdf
