Question about Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB
How to set up forutube
How to connect to internet
  • Hisense Master
  • 4,062 Answers
Recommend using the installation and setup procedures straight from the manual. Unfortunately, I cannot access the manual, but I recently set up a new Smart TV and found that the manual is essential to making it easy and painless. The added benefit was that I learned how to properly use my TV easily.
Good luck,
Posted on Mar 02, 2015
SOURCE:
Just bought my kids a ps3 but we cannot figure out how to connect it to the internet?
Any of the two will work it all depends on preference. If the modem or router is too far from the console then you would most likely want to go wireless. Here are instructions how to do each:
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Hi, Having problems connecting the PS3 to the Internet?
There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
Step 3: Select "Internet Connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 5: Select "Wireless" to choose what kind of Internet connection you want.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home internet access point requires a password enter the password when prompted and save your settings.
How to connect PS3 to the internet?
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
What do I need to connect the PS3 to the internet so my boys can play online ? Hardline or will WIFI work ?
WIRELESS (WIFI):
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
No puedo conectar mi ps3
WIRELESS (WIFI):
Feb 19, 2011 | D-Link DIR-300 Wireless Router
Can i hook up my ps3 to a wired internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
How do i jook up my playstion 3 to the internet via time warner wired connection
1st Step: Setting up the Internet Connection
When making a wired connection to the Internet, you do not need to adjust any of the default settings. If you cannot use the default settings to connect, follow the instructions below to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, and then press the X button.
  • Select "Internet Connection Settings", and then press the X button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the X button.
  • Select "Wired Connection", and then press the X button.
  • Select "Easy" or "Custom" and adjust settings as necessary. (Easy is recommended)
  • Follow the on-screen instructions to adjust the required setting.
Easy: Basic settings are set automatically.
Custom: You can manually enter detailed settings information.
Here's a diagram set up to PS3 wired internet connection
You can take a look at the connection diagram here
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Wireles connection shows connected but cannot open any web page
check your internet settings
for Internet Explorer
1. open browser, click tools menu the select "Internet Options"
2. in Internet Options select "Connections" tab
3. at Connections, click "LAN Settings"
4. at LAN settings "Automatically detect settings" should be mark check
5. click OK to save settings, close Internet Explorer Browser and open it again.
for Firefox Browser
1 open browser click "Options" menu
2. at Options, select "Advance" then select "Network" the click "Settings"
3 Connection Settings, select "Direct Connection" if your computer directly connected to Internet provider otherwise select "Auto Detect Proxy Settings" if your using a Router.
4. click OK to save changes, close youi browser and open it again.
Hope this will help you.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Internet connection
want to set up internet connection then go control panel-click on network and internet connection click the set up internet connection then click connections tab then set up follow the instructions you will be set up
Apr 08, 2008 | Computers & Internet
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
136 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
