Camping, Backpacking & Hiking Logo
E
Edwin Posted on Mar 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook up the two batteries in a Vector 190 sport spotlight. I need to see a wiring diagram for the battery connections.
I removed the 2 batteries AND there is a jumper to connect to the second battery I do not know how this conntects to the main leads then to the second battery.
ka4iup
Level 3:
  • Master 4,062 Answers
  • Posted on Mar 02, 2015
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1095336
Points
51404
Quick look at the manual tells me that it is a 12v light, powered by two 6 volt batteries. This means that they must be connected in series. Identify the positive and negative terminals on each battery. You also need to look at how the power is supplied to the unit - i.e., are the batteries connected front to back? The jumper of one battery will connect to the negative terminal to the positive terminal of the second battery (this is a series configuration.) Make sure the batteries are oriented in the proper position in the unit before sealing it up.
The manual can be downloaded from here: http://www.manualslib.com/manual/185814/Vector-Sport-Spot-Vec190pob.html#manual
2helpful
2answers
1helpful
2answers
I have a vector 1 mil candlepower sport spotlight haven't charged it in a while,and doesn't seem to want to charge.Does this mean the battery pack is bad?
Unfortunately the batteries lose their ability to charge when not used for an extended period of time. The light is very simple to dismantle by removing the black rubber ring that holds the lens on and then removing the screws. I believe the following battery may be the replacement you need.
http://www.batteryspec.com/cgi-bin/cart.cgi?action=link&product=313
2answers
My Vector Flash light is not working, I have tried to fix localy in Santa Barbara, but was unable, there is a place to send them to be fixed, my model is Sport Spot 3 million, thanks
Baccus just bought Vector from Black & Decker (Sept. 2010)
Looks like flashlight model # VEC 139BW but a different color. (Mine is White w/blue trim.) There is a battery in the top & one in the bottom, replace them at the same time. If I can find several battery stores in Buffalo you should be able to find a local battery store there.
Baccus- 877-571-2391 for main beam, area light no longer available. Try to find local distributor & save shipping charges.
1helpful
Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
9helpful
5answers
1helpful
3answers
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
3helpful
2answers
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Top Vector Camping, Backpacking & Hiking Experts
ZJ Limited
ZJ Limited
john h
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
