Bella High Power Juice Extractor Logo
A
Anonymous Posted on Mar 02, 2015
Does Bella Juicer take celery? - Bella High Power Juice Extractor
Rick Ostrowski
Level 2:
Sergeant:
New Friend:
  • Expert 153 Answers
  • Posted on Mar 02, 2015
Rick Ostrowski
Expert
Level 2:
Sergeant:
New Friend:
Answers
153
Questions
Helped
58170
Points
530
I am looking for e celery juicer
I think Cuisinart has a pretty affordable juicing line.
Jan 12, 2020 • Juicers
tip
How to keep your juicer from jumping all over the place.
I have found celery is the big problem, instead of putting in the whole stalk cut
it into small 2 inch pieces, when I do this I have no problem, otherwise my
juicer is jumping all over the counter. I believe it is the long strings in the
celery that somehow gets caught around the parts. At least it has made
juicing a pleasure for me. Hope it works for you.
If this has helped you please let me know, [email protected]
Need instruction manual for Bella Nutripro juicer 13695
I found the manual for the Sensio Bella Nutripro cold press juicer (13695) on Manuals Lib: https://www.manualslib.com/manual/725679/Sensio-Bella-Nutripro.html . If you want to download the manual, you can click on the Download button near the upper left corner of the web page. You will need to deal with the "I am not a robot" question to download the file.
I hope this helps.
Jan 04, 2018 • Juicers
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and...
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
I juice mainly green vegetables: kale, spinach, etc, then carrots -and it doesn't have enough power, slows down and then stops - any idea why?
Sorry, but it's not designed for leafy vegetables.
Carrots, apples, celery-yes. For kale, spinach
try a inexpensive, hand powered, wheat grass
juicer. About $50.
2helpful
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
2helpful
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
1helpful
2answers
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Top Bella Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bella Juicer Expert? Answer questions, earn points and help others
