SOURCE: I got my Casio G-Shock
mcdevito75 here, Return to the shop for this adjustment. Or you can try, press the mode button, see the display flashing, now press set for each function you want, after each function press mode again to move onto next function, hour minute etc., when all functions are set, presss mode again for steady display. You may have to press and hold down mode button from the start for 2-3 seconds to see display flashing, once you do, you can use set to adjust all functions.
SOURCE: how to set the time for casio aw-591(4778) details
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4778.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
