Cooktops Logo
A
Anonymous Posted on Mar 02, 2015
How do i locate electrical schematic for meile cooktop km5656edst
Meile cooktop km5656edst don't have electric schematic have problem with large burner out ring not coming on may u advise or please show electric schematic
Eugene Schwarz
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Mar 02, 2015
Eugene Schwarz
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
5552
Points
34
Google search for meile cooktop km5656edst schematic
Installation manual aeg 32kw 380volts motor needed asap
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
2answers
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Three small burners work three large dont
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
I need the drip pans ( one large & one small) for the burners on my jenn -air electric cooktop c221
I was able to get the items at a local distrubitor. Thanks for your prompt response.
3helpful
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
5helpful
2answers
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
13helpful
5answers
Electric coils for old Thermador cooktop Model #TMH45
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Jul 20, 2008 • Cooktops
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
