The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
own LG washing machine Top loader, Model WF-CL700 and the problem is, the red light indicator show to wash and spin after 1 or 2 times turning then stop turn followed by the alarm sound..
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve. It is best to remove them , check reset after cleaning.
Hi, Problems with a washing machine not spinning or not draining are often inter related.. If you are having a problem with your top load washer then check out this tip...
I have a LG WF-T 7016PP it does not want to go from wash to rinse to spin. I must manualy take it through all the stages. It works perficly on all stages but just does not want to switch over automaticly.
