My mx500 is charging but it only makes a clicking sound
Most likely, the last 2 answers are correct. When you charge the battery, does the light on the charger stay red for several hours before turning green? Check the voltage of the 3 batteries after the charger light turns green. It should be 39-40 volts or so no load. Turn the throttle and see if the voltage drops when the relay clicks. You can connect the batteries directly to the motor and it should go full speed if they are good.
SOURCE: The MX500 wont start. The light says the battery
Although you alternator may be charging, the battery may not be accepting the charge or holding it. Have the battery tested under load, but I think that you are going to find you will need to replace it.
Testimonial: "Thanks for the quick feedback. I appreciate your help as I am a novice at this."
