The error code "ch 12" is flashing on my air con unit and it switched itself off
Connect the remote controller cable to
the wired remote controller installation board as shown in the right picture. 12V SIG GND Red wire Yellow wire Black wire 12V SIG GND 4. After fixing the
top part of the remote controller to the installation board as shown in beside picture, press the bottom part to assemble the controller to it's board. When
disassembling the remote controller from the installation board, use the driver as shown in the right picture and insert it into the hole with the arrow. And
when you pull the driver in the front direction, the remote controller will be separated. Wall Side Wall Side ENGLISH Red Yellow Black Remote Controller
Cable ?The remote controller cable is connected as factory default. Wall Side Wall Side 2. After fixing the cable to the guide slot, attach the wired remote
controller installation board at the desired location.
Problem Ch 12 Ans. Me plzz
Its indore pipe sensor failure or disconnect
