Best way to unlock pattern lock on any pattern locked device is whit unlock pattern lock software available for free download on this page : http://www.unlockphonetool.com/how-to-unlock-pattern-lock-on-any-device/ How To Unlock Pattern Lock On Any Device
I would like to recommend an app named LEO Privacy. Because it's really an awesome app for privacy. it has mutiple unlock ways to protect your phone, such as password, pattern, cover and custom unlock theme background. LEO Privacy Applock Boost Hide Android Apps on Google Play
Follow these instructions Factory Reset on Proscan PLT7223G or Tablet
Hello Heather
You were supposed to remember the pattern you gave it when you locked it. That's why they have the Lock. To keep unauthorised people out.
Give it the right pattern is all I can suggest!
SOURCE: I have locked my MID Android Tablet. I have
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
SOURCE: I can't get my tablet unlocked(dot pattern) any ideas?!
On an android tablet there is generally a button combo, you can google your specific model for the answer. For instance, you might turn the tablet off and then hold the power button and the volume up or down button.
SOURCE: help how do hard reset my proscan tablet plt7035 i
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
After a few attempts to guess pattern it should prompt for the gmail account assigned to the phone. Then allow a pattern reset and confirm.
