Dryers Logo
A
Anonymous Posted on Mar 01, 2015
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the tumble dryer is warm to touch. I was wondering what this could be.
Ken Wieczorek
Level 2:
Sergeant:
  • Hotpoint Expert 451 Answers
  • Posted on Mar 24, 2015
Ken Wieczorek
Hotpoint Expert
Level 2:
Sergeant:
Answers
451
Questions
0
Helped
227972
Points
825
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
4 Related Answers
Anonymous
  • 55 Answers
  • Posted on Mar 10, 2008
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
douglas smith
  • 1462 Answers
  • Posted on Jul 23, 2008
SOURCE: Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 13, 2009
SOURCE: Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Anonymous
  • Posted on Jan 09, 2010
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Hi, I have a Hotpoint Aquarius TCM570 7kg. It was working the other day but kept cutting off so would wait until it cooled down and then turned it back on. Now it’s not working at all so changed the fuse...
You need a technician for issues like that. Overheating is dangerous. Yikes, there is a RECALL on that model!!
Whirlpool tumble dryer recall: full list of Hotpoint models being ...
https://inews.co.uk > news > consumer > whirlpool-reca...
Nov. 2, 2019 - Whirlpool recall: full list of Hotpoint tumble dryer models recalled - and how to get a free replacement. Whirlpool admitted as many as 800,000 ...
https://www.hotpointservice.co.uk/safety-notice
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
My Hotpoint Aquarius TCM580 tumble dryer has the "Empty Water" alarm in constantly despite the water container being empty. When the "Empty Water" indicator lights, the heat is turned...
I had this issue and the answer above about tipping your dryer / cleaning the condenser worked a treat for me. So thank you to whoever posted it. And don't forget to clean your filter, bottom front, regularly. I keep forgetting this and am sure it probably contributed to the problem.
Jun 22, 2011 • Dryers
1helpful
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
1helpful
Jul 23, 2008 • Dryers
1helpful
3answers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
Mar 09, 2008 • Dryers
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
