Motorola Mobility i856w DEBUT IDEN/GSM UNLOCKED BOOST MOBILE Logo
A
Anonymous Posted on Mar 01, 2015
How do I turn on my phone. It set it down for about 3 minutes and now it isn't turning on anymore, a green light keeps blinking
  • Official Brand Answer 1,623 Answers
  • Posted on Mar 01, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350288
Points
5677
Pull battery out. Press power for 15 seconds. Then put battery back in and charge for an hour. Then try to turn on.
Mark
Motorola Support
Green light keeps flashing
A Green light or White light maybe blinking while the TV is turning on. This is normal and will stop once the TV does come on. If the light continues to blink and the TV does not come on or if the TV comes on and then turns off and the process starts over again, and unplug the TV for about 3 minutes then plug it back in and try again.
My canon ir 5180 blinks only d green light but d screen does not open
Start with the printer OFF:
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
0 - green - Pressing power button will turn off printer
1 - orange - Service Test Print
2 - green - EEPROM Information Print
3 - orange - Initialize EEprom data
4 - green - Reset Waste ink Counter
5 - orange - Mode to set Destination code
(1: Overseas, 2: Domestic)
6 - green - Refresh printhead (cleaning mode)
I assume the printhead is cleaning and you need to wait for it to finish cleaning. That could take over a minute and a half; I don't know what that delay is for your printer.
If that is not the issue, you may have to reset the printer. This may be possible as follows:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn't power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Release the buttons and simply power it back on. (If you unplug it without powering it down, you may get an improper shutdown error message. If so, click OK on the printer.)
If you are looking at a blank computer screen after all of this, you might try uninstalling and reinstalling the driver.
If this does not fix the problem, you better look into troubleshooting on the manufacturer's site for help for your particular printer.
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Lost my instructions to operate the remote control. I have the code list, but i don't know how to imput the right code on the remote. My model is JER321
Configuring codes:
Turn on the component that you want to set up.
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Thanx
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Printed pages come out blank
Hello please try this
1. Turn off printer
Panasonic 52 inch TV turns on and turns off after 2 minutes
thi set will need repair , one of the circuts in the power section is failing and will need test to determine the exact cause of the failure, you will need to call your local electronic repair shop to come and take the board out or they will fix it there
if you need anymore assistance don't hesitate to ask
electech
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
1helpful
4answers
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Top Motorola Mobility Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
