After power on, all water level lampshigh/medium/low are blinking at the same time with beeping. Then, no other buttons work. No water, no spin. Could you explain why this happens?
SOURCE: spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
SOURCE: Haier HLP21N Washer will not Wash or spin cycle not working is this a level problem?
main suspects are lid switch or fill level gage lid switch
pressure sensor switch
Testimonial: "how do I go about fixing them ?"
