Question about Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005
Rear drivers side seat is stuck down on my Mercedes 2004 ml350, how can I get it to release and come up
Put seat down and it stuck in that position...lever does nothing
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 3 Answers
The best thing to do take the entire back seat out then find the problem and fix it. also check in manual guide it could be anything from spring and anything else, if you have to press a button to raise the seat up and down first check the manual guide then check the fuse.
Posted on Mar 05, 2015
SOURCE:
Aux battery location in 2009 ML350 Mercedes?
It is located under the passenger seat. May have to loosen the pass front seat mounting screws and remove the two rear screws and lift the seat up at the rear about 3 inches to replace it.
https://www.youtube.com/watch?v=o7hfpkJrfLo
https://www.ebay.com/itm/Mercedes-W164-W251-GL-ML-R-Class-NEW-GENUINE-Auxiliary-Battery-1-2AH-/112041275311?_trksid=p2349526.m4383.l4275.c10
000000 004039 Genuine OEM...... Other Part Numbers: 82533004001 / 825 33004 001 / 000000 004039
Nov 24, 2017 | Mercedes-Benz Cars & Trucks
The rear drivers side passenger seat in my Mercedes 2004 ml350 is stuck down...how do get it to come back up. very little room to work
Not an easy task. You likely have one of 2 problems. If center seat belt is in the seat that is down, it may be locked. If so, you need to remove the seat back cover then the seat belt retractor. You can then position the seat belt retractor upright (how it sits when the seat is up) and pull the seat belt out making slack to raise the seat. This only happens if the either the stop on the seat belt is broken or the seat belt guide on the seat back is broken. If that's not the problem, you likely have a release cable that has come loose under the seat. If you look at the half that works, you can determine what you need to move on the locked seat and try to get to it with a long tin screwdriver or similar implement.
Mar 01, 2015 | 2004 Mercedes-Benz ML 350
there is a cable that runs from outer handle on the seat and connects to a rotating tube/latch at the inner seat frame. you will need to use a long flat scew driver from behind that part of he seat to slip in theat latch and twist to unlatch that seat then you canr repair the cable.
Mar 01, 2015 | 2004 Mercedes-Benz Mercedes Benz S Class
How to remove rear passenger door panel from 2004 mercedes ml350
remove any screws around the panel,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tom_db3a51ff0ca57f20
Jul 18, 2014 | Mercedes M-class Ml Ml350 Ml500 Ml55...
I have a ml350 mercedes ,,trunk won't open
All new model cars are built with a manual release inside the trunk it glows in the dark and is lime in colour Lower the rear seat back shine a flash light in there find the manual release and pull it down Trunk will now open Check the lock striker to make sure it isn't obstructed then also look at the rubber knobs to see if they are not turned up too high which would keep the trunk from opening with the remote You can always use the key to get in there The key is inside the bottom of the key fob Just look for the little clip on the bottom of the remote to release the key inside
Apr 24, 2014 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
Need to remove the rear passenger interior door panel on a Mercedes ml350, 2005. How?
Try pulling from bottom or a spot to put ur gingers in and lift up and pull
Sep 24, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
Remove rear passenger door panel Mercedes ML350, 2005
Open crank window.
Remove cover for door handle and unscrew 2 screws.
Unclip SRS panel and unscrew screw.
Press door liner off bottom, fron and rear inner door panel with wedge.
Lift door liner up and out.
Unhook inner door actuator.
Unclip inner lock on door liner.
Remove lamp.
Mercedes stuck in 4 wheel low
What speed was being driven when you this was attempted?
Feb 03, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
Rear Seat on C Class coupe will not release think I ned to take the seat backing off to look at the mechanism
i beleive the release handles are in the trunk. Unless the release handle broke or cable is broken it is probably out of adjustment. Try having someone lean into the seat backrest and then pull release handle. I'm assuming your talking about your backrest release. If you are refering to the seat cushion-they can be tough but try putting some weight down on the cushion and then try pulling the release handle at each side of the seat.
Jul 14, 2009 | 2001 Mercedes-Benz C-Class
2004 Saturn Vue - Getting Rear Seats Back To Upright Position
Push down on the seat then pull the handle or both at the same time then pull up while holding the release up, it got me at first, but thats how i got it
Jan 06, 2009 | 2004 Saturn VUE
Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005 Logo
218 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
