Building Materials Logo
A
Anonymous Posted on Mar 01, 2015
How many cubic meters of concrete will it take to pour a garage fool 336 sq feet 6 inches deep
James D Wallen
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Oct 08, 2016
James D Wallen
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
2433
Points
6
Knowing how much concrete is needed for a job is an incredibly important thing. Nobody else, then professional concrete contractors like concrete contractors Rockville MD at:- http://capitalpavingconstruction.com/ can give you an accurate idea of how many cubic meters of concrete will it take to pour a garage full 336 sq feet 6 inches. Here you will find helpful hints and information about calculating just how much concrete mix you will need for your job.
B Sea
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 01, 2015
 B Sea
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
6469
Points
37
Since it's 6" deep then it's half of your surface sq. footage = 168. That converted to cu. meters is 4.8 cubic meters as 1 cu ft = 0.0283168.
That said if you live where there is frost in the ground, the building code may require a bit of a deeper footing around the perimeter so it's best to check your local building codes.
Marilynn Hinton
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
Marilynn Hinton
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
7276
Points
20
Figure 1 90 lb. bag per square ft., 6" deep.
Don't forget sand to grade and rebar to reinforce.
You probably won't find enough guys to mix all that concrete, so you'd really be better off hiring a concrete truck.
Tip: It's best to over estimate a little so you won't be caught short.
2helpful
2answers
Area 40 ft long 4ft wide 5 inches deep how many sq yards needed
First step - convert everything to feet - 5" is 5/12 of a foot
40 x 4 x 5/12 = 66.6 cubic feet.
Since a cubic yard is 3 feet by 3 feet by 3 feet, there are 27 cubic feet in a cubic yard.
66.6 cubic feet / 27 cubic feet/cubic yard = 2.5 cubic yards.
Good luck.
Paul
How many cubic feet of soil do i need to cover 12x15x3x3 garden
you have to many numbers there
If you are saying 12'x15'x what deep 3 inches or 3' ?
12'x15'=180 sq ft x3' = 540 cubic feet or 20 cubic yards
x3inches= 40 cubic feet
1helpful
3answers
How many yards to cover 30ft/40ft 4 inches deep in concrete
That may be ok for the US, but in Europe you would need cubic metres.
I yd = 0.914 m, 1 cubic yd = 0.914 x .914 x .1914 = 0.764
So 14.66 cu. yds is 14.66 x 0.764 = 11.2 cubic metres - with a bit of luck!
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
2answers
What is the cubic feet equal to 30" x 25" ?
You need three dimensions for a volume.
30 inches by 25 inches is 750 square inches or about 5.21 square feet.
How many cubic feet would I need to cover 1000 sq. feet.
How deep do you want to cover it?
1000 square feet covered one inch deep would be about 83.3 cubic feet.
1000 square feet covered one foot deep would be 1000 cubic feet.
1000 square feet covered two feet deep would be 2000 cubic feet.
1helpful
Cubic feet calculator
just under 18 cubic feet.
at 4 inches thick there will be 3 square feet to equal 1 cubic foot. there's .6 cubic feet in an 80 lb sac. I'd get 30 bags and be careful not to go over 4 inches deep to often.
How many tons in 3 cubic meters sq by 3inchs deep
I am sorry to say it but your units do not make sense: Units of volumes and areas are mixed up.
Let us try to make sense of it.
If you have some container whose base is 3 square meters (not cubic meter sq) and it has a height of 3 inches you can calculate its volume in cubic meters or in cubic inches or cubic feet. To do so convert the height in inches into meters and multiply the area of the base by the height in meters and you will obtain the volume in cubic meters. To get the volume in cubic inches convert the area of the base to square inches and multiply by the height in inches.
However, even after you have expressed the volume in one unit or another (m^3 or in^3) you cannot find the mass of the substance contained (be it in tons, tonnes or kilograms): You need to know the substance and more specifically its density or its specific gravity).
Please, reformulate your question and specify the substance that fills or would fill the volume. Without that information, nothing doing.
Trying to convert 2600 sq ft 5'' deep into cubic yards
The answer is 40.123456789
To convert square feet to square inches x 144 (i.e 12 x 12)
1200 x 144 = 374400
Multiply by 5 (depth) to give cubic inches
374400 x 5 = 1872000
To convert cubic inches to cubic feet divide by 46656 (36 x 36 x 36)
1872000 / 46656 = 40.123456789
Hope this helps,
Matt
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
