GE PT956CMCC Profile 30" Built-In Double Convection/Thermal Wall Oven - Bisque Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Anonymous
Level 2:
Scholar:
  • Expert 83 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
50481
Points
224
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
Anonymous
Level 2:
  • Expert 121 Answers
Anonymous
Expert
Level 2:
Answers
121
Questions
Helped
48338
Points
320
Try to unplug from wall about 30 min,then turn it on,then if you have clock on oven adjust it.
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 • GE Ovens
We had a power cut this morning ours is a double oven, the small oven/grill works but not the main oven also there is no clock on
This fault is unlikely to have been caused by power outage. Disconnect from mains, remove rear panel and look for damage in the area where the power cable connects to the iven
Nov 24, 2014 • Ovens
After a power outage there is nothing lit on the oven. No clock, temperature or oven mode
Hi Most ovens have (fuses) in them check and/or replace if blown. Also if there still is no power check main breaker pannel to building.
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 • Ovens
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 • Ovens
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Nov 05, 2007 • Ovens
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
