John DEERE CONSTRUCTION LOG SKIDDER NIP 164 Logo
A
Anonymous Posted on Mar 01, 2015
How do i stop the engine running at a fast idle
Just put new injection pump on and it runs with fast idle how do i correct this
Vernon Taylor
Level 3:
  • John Master 7,446 Answers
  • Posted on Mar 01, 2015
 Vernon Taylor
John Master
Level 3:
Answers
7446
Questions
0
Helped
1959316
Points
26207
Assuming it is a completely mechanical system with no electrical or electronic control there is no actual fast idle facility unless it is provided by a Waxstat cable device fitted into the cooling system.
I think what you mean is the engine idle speed is too fast rather than it is running at "fast idle" which is a term used for a raised idle speed when an engine is cold and decreases as the engine warms until at normal operating temperature the idle speed should be normal. On an old diesel engine it is the Waxstat device if fitted that provides this facility or a hand operated throttle. Very old cars and trucks had hand throttles for fast idle but later this function was provided by the choke or strangler mechanism. Some luxury cars had an electrical device fitted but the fast idle of modern engines is invariably provided by electronics.
I expect you need to adjust the throttle stop screw of the injection pump. This is at the lever where the throttle linkage connects to the pump and there is generally two stop screws fitted that limit the travel of the lever. One screw limits the maximum travel of the lever and therefore the maximum engine speed and this is generally set during manufacture or remanufacture and sealed to prevent tampering.
The other screw is the idle screw which the lever is pulled against by a spring when at rest.
Before adjustment it is necessary to ensure the throttle linkage is not maladjusted and preventing the lever contacting the stop. Disconnecting the linkage until the idle speed has been adjusted will ensure this and then slacken the stop screw locknut, start the engine and turn the screw in or out as applicable until the desired idle speed is achieved, allow the engine to warm up and make further adjustment if necessary and tighten the locknut and reconnect the throttle linkage. Do not adjust any pump screw except the idle screw.
Ok I got saw running good fast but won’t idle?
the sequence to throttle adjustment is to adjust to high speed first ( screw closest to the air filter) turn in in or out until it fires evenly at rpm and picks up rpm easily
now hold the throttle at full throttle and slowly idle down while adjusting the idle screw ( closest to the butterfly) to maintain engine running
the screw should have been turned all the way in then back out 1 1/2 turns before starting the engine
keep slowing the engine while making very small adjustment until it idles at rpm slow enough that the chain is not driving
If you get it low but it stalls out , then adjust the throttle stop screw to maintain idle rpm
Correct adjustment is from this point the rpm increases rapidly with out falter ( fine tune high speed screw to achieve that)
and when left to idle will do so evenly without driving the chain
all of this working is depending on the carby having new diaphragms , needle height adjustment correct and the system cleaned out
Apr 11, 2018 • Fast Garden
1989 Chevy Blazer 2 yr old fuel pump new in line fuel filter runs then dies when putting in gear then starts back up?
If you are saying,the truck is at idle,then you select drive and the engine slows/almost dies then picks up engine speed back to correct speed,then you most likely have a slow/defective/gummy IAC ( idle air control ).A replacement may be necessary but I would clean it first.It is found on the side of the fuel injection housing.After removal and cleaning or replacement it may have to learn a new position for correct air flow and that may take a minute or two with you sitting stopped with the truck in drive.
Why my 97' f-250 7.3 powerr stroke keeps dieing while idling
The power stroke engine has several things that will cause this problem #1 crank shaft sensor AKA cam shaft sensor on crank shaft located on passenger side of engine near crank shaft pulley # 2 IPC sensor Injection pressure control if has oil in sensor replace it & wiring pigtail .#3 high pressure oil pump not up to par. #4 injection pressure regulator solenoid they get sticky. with a good scanner that has FORD enhanced software you can check all of these without leaving the drivers seat and perform running tests on injectors and test the ficm module interface with the pcm. Fuel Injection Control Module & Power Control Module.
I have a engine problem..about my idling..when i step off the gas the engines stops..and i can only run fast for only 80km per hour...since my engine suffers from that problem..can you help me to solv
an aggressive fuel injection service;"Sea Foam" right at the throttle plate. Remove and clean the EGR valve and its related components within that circuit. Correct any vacuum leaks that may exists, of which is one of the main reasons why fuel injection and emission systems begin to fail. Remember that's what OBDII is all about???
1990 4.o will start and run but when engine warm up,emisinos light comes on and then fuel pump loses pressure,
i think the problem is this joseph, its an inbread p.o.s of a vehical.you should burn it and buy a 350 chevy ha ha ha!
1helpful
3answers
I have a 1985 toyota pickup (fuel injected)with a 22re engine, it will run on starting fluid, when i spray it but it wont run otherwise, just put in a new fuel pump, thanks for youre help,
Alright, i have a 1987 Toyota 4x4. it has a 22RE full injected motor..it was able to run, but it was running rich, and idling pretty eratic..and then now..it only starts up..and dies. after like 5seconds.
3answers
2answers
High Idle On Start-up.
Sounds like you have a intake leak. You're getting extra air into the mix until she fully warms up. Check where the throttle body meets the heads.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Carby runs good cold then terriable
Hey nake sure your timing is correct or also that ur glow plugs are still holding on strong there is also a few other problems it could be like ur fuel injecters cud be blocked or your injector pump may be leaking or sucking air!!! best of luck hope it help alittle!!
Chantelle
Top John Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a John Toy Expert? Answer questions, earn points and help others
