If you have purchased a Samsung smart TV with Smart Hub you will be able to connect to the internet using the web browser found in the Apps when running Smart Hub function.
You will need to have either an Ethernet cable connected to your TV from your router or you can connect using WiFi is your TV is so equipped.
You need to use the menu to go to the internet connection setup.
I hope this answer is helpful to you.
