Hello, I dropped my PS3 and it won't turn on now. The capacitors in the power supply are bulged. Could this be caused by the drop? Thanks.
Caps arent supposed to bulge but hard to say that a drop caused it.was the power on when you dropped it? ..you can always test the caps with a multimeter to see if they are bad. I would guess that a bulging cap will cause no power, but it may not be the only issue...Good luck
Not likely. Caps are likely bulging due to heat, and are near end of life. Even if you didn't drop it, it would fail when a cap failed altogether.
