General Electric GE Profile SpacemakerR XL 1800 36 Microwave Oven Logo
A
Anonymous Posted on Mar 01, 2015
CHANGE THE BULB - General Electric GE Profile SpacemakerR XL 1800 36 Microwave Oven
Jerry Smith
Level 3:
  • General Elec... Master 473 Answers
  • Posted on Mar 02, 2015
Jerry Smith
Level 3:
Answers
473
Questions
0
Helped
145415
Points
1230
Remove the top grill assembly. It is usually held on by 2 screws going down through the cabinet top. You may need to tap the grill to the left slightly to get the tabs to release. Once the grill is off, look near the middle of the top edge of the microwave frame for 1 screw that looks like it goes through a metal lip. It will be right above the inside light bulb area. remove screw and then pull the metal tab towards you. The complete light bulb assembly will slide up and out towards you. Replace bulb and reassemble microwave.
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
1helpful
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
How do I change the bulb in Alba TRDAB2820 radio
back-light bulb is actually LED's and these fade when the capacitors fail 4 X 470uf at 10v and 1 X 1000uf at 16v on board behind display, change all 5 and it should be ok again.
Martin
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
8helpful
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
4helpful
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
2helpful
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, [email protected]
How do you change the bulb
First, take off the cover and you will see the bulb. You must have the unit unplugged and do not touch anything else inside the unit after you take off the cover. Theres a capacitor in there that holds a big charge.. Change the bulb as you may have to go to the hardware store as it may not be a regular bulb Most are not. Good Luck
Top General Electric Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
