For the past month or so, I have not been able to listen to channel 94, because the screen displays the following words 'CH UNAURTHORIZED'. Why is this
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
on the TV screen.
channels.
OK.
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
Different channels and fields display different information, such as additional
languages or supplemental information
