I have a Bosch nexxt 500 series dryer. The heating element wouldn't heat. I took it apart cleaned it put it back together and now all it will do is click
probably not the heating element but one of the toc's has gone(temperature overload cut out)if you are handy with a multimeter test it and if it shows the symbol 'ol' youll know which one is gone
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Check your voltage. Take a volt meter and make sure it is set on 250 or higher volts. All electric dryers needs to have 220 volts going to them. One 110 goes to the motor and one goes to the heating elements. If you are only getting 110 volts only one side then it is your electrical problem. Check your breaker or fuses.
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Open the front panel, remove heat exchanger and clean. also clean out lint tray.
this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
