Voice mail is usually set on first button (number one) of dialer and when you press it for long time you get an message to set the voice mail number if not set earlier or by default. Just ask your provider for voice mail number and put it when requested.
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text. How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now. 2. When you set up your voice mail: * You'll register your mobile phone number. * Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call. * Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you. * You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail. * Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail. * Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
sir the voice mail box is a network service to which you may need to subscribe .for more information ,contact your service provider .to call your voice mail box ,press and hold 1 .........to edit your voice mail box number ,select menu >messaging >voice messages >voice mail box select the following settings to setup the voice mail
put your voice mail number in voice mail settings or you can dial directly your vc number to listen your voice mails,if you dont know your voice mail number then ask your network operator for number
Setting Up Your Voice Mail from page 10 in your manual: Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail 1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail. After connecting, you will hear your voice greeting. 2. Interrupt your greeting by pressing . 3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time. JimmyC
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it.
This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail.
I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail.
Did you set this up yourself? How did you program the phone system?
