find command screen on windows computer. XP it is under accessories. On windows 8 you have to use the search facility to find CMD.
On black command screen enter command
PING "server name" where "server name" is the server you want to find such as Microsoft.com.
Call the "Support Desk" of your Internet Service Provider, if that "DNS Servers" line is blank -- or even if it is non-blank -- ask the ISP what the values *SHOULD* be -- just in case your computer has been "hijacked" to point to "rogue" DNS-servers.
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
1.Create a blank file and call it "myfile.php" – The file must end with the ".php"
2.Use only this line of code -
<?php phpinfo() ; ?>
3.Save the file and upload the file to your website server.
4.Go to www.mywebsite.com/myfile.php
If you see the line of code you wrote, it means you can't run PHP, if you see the PHP information it means you can run PHP on your server.
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
