Question about Hotpoint Ultima WF865 Front Load Washer
Where is filter to drain pipe please
Water not draining out and no spin! Think its blocked pipe
    Genius:
  • Hotpoint Master
  • 1,585 Answers
I think its up inside the flutted black hose going from mechine to pump
Posted on Mar 02, 2015
SOURCE:
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
My Hoover BOSS 2315l started having issues not finishing the spin cycle, now it just continues to turn off every few min, so I need to keep restarting it. Does anyone know whats wrong please.
Symptomatic of a blocked drain pipe, blocked filter, or a failed drain pump, drain pump with a broken impeller.
Remove the filter cover and check for obstructions. Attach a hose pipe to the drain hose, wrap it with a towel, hold the two hoses over a bucket and get someone to turn the hose on until you can't hold the pipes any longer, usually about 15 seconds. This clears obstructions in the pipe into the machine drum and filter. After checking the filter and behind it, put it on for a rinse and spin.
If the pump has failed, you can drain the machine by lowering the drain hose into a bucket or floor drain.
There are videos online on how to change out a faulty drain pump.
Jan 22, 2018 | Hoover Washing Machines
Water fills up in the tub but won't drain from the washer.
Filter may be blocked. Be careful taking it out, you will get flooded. Make sure you have something to collect the water as it rushes out. Also check the main drain isn't blocked. If you know how, unplug the rubber waste pipe at the back of machine (not from the bottom of machine but from where it connects to main drain) and see if the machine empties by running spin cycle. If water comes out of pipe then it's the main drain....if not it's either the pump or filter.
Nov 13, 2016 | Washing Machines
I have a Hotpoint WMA50 it does not drain. It spins but water stays in machine can you help please
check the drain pipe is not blocked check the filter as well
and check the pipe is not kinked or something if that is all ok poss the pump is us
Oct 12, 2014 | Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
No problem with wash and spin cycles but will not drain water after wash. Makes a ckicking noise when it should drain away
It sounds very much like there is a blockage in the drain pump,when was the last time you checked the filter.It may be spinning ok but if the filter is blocked it may not be spinning fully or draining properly.There is also a good chance that the sump pipe and drain pipes are choked with sludge /limescale.Try the filter check first if no Joy then it will need investigating down by the pump.
Hope this is of some help.
Good Luck.
May 04, 2010 | Zanussi FJS1225W Front Load Washer
Spin cycle is spinning at about 50%,it is draining but slowly
Hi, if the drum is full of water or not fully empty, this will prevent the spin from working.
If you have a drain filter, see if it's blocked.
You may have a blocked drain pump, a block in the outlet pipe or the drain pump is failing.
All of the above should be simple to check and cheap to repair.
Hope this helps
Oct 14, 2009 | Whirlpool Washing Machines
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
