Firstly (1) will be Black=hot, White=neutral and Copper=Ground. Don't work on these wires with them live.
All copper wires will be connected together and if possible, the metal box earth lug.
You will need a SPST or SPDT switch (image of SPDT switch is shown below) to mount in your junction box. If your switch has a ground lug, you need to also connect the copper wire there.
(1) Black will connect to Switch Common, (3) Black and (4) Black. Note: all can connect to the Switch Common connection as the switch will generally allow 3 wires to be connected per terminal; one push terminal and two screw pressed terminals.
(1) White will be connected to (2) White, (3) White and (4) White. For this connection, you can use a twist cap of the correct size to parallel these neutral wires.
(2) Black will connect to other free connection on the switch. There may be two free connections, so the one you use will basically determine which direction the switch will be on/off.
Once connected and checked, you can power up. If correctly wired, you should now have switched power to (2) and continuous power to (3) and (4).
I hope this helps with your inquiry.
