Question about Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
The machine make a loud clanging grinding noise, and it will not spin or agitate. What could it be. It is 10 years old and this is the first problem I have had with it.
  • 9 more comments
  • BDM8956 Nov 14, 2007
    I'm having a silmilare problem but I checked my copler out and it in perfect condition, What would be next in line to check? is'int there a clutch on top of the motor?
  • Anonymous Dec 02, 2007
    Kenmore washing machine will not spin. I assume it is over 10 years old - came with home I purchased three years ago. Do I need to purchase new one or can a repair person repair it and is it worth it to repair????
  • Anonymous Dec 24, 2007
    When turning the inner spin cylinder clockwise, there is a loud sound in the same spot, each time the basket turns. Also, you can see the inner basked slightly drop at the same spot during the sound.
    I went through the bolts and they seemed pretty tight, it seems as if the problem is inside one of the casings. What is the issue?
  • Hitesh1 Jan 08, 2008
    I have the same problem, can you provide us contact number & let me know what are the charges if someone can personally attend this & how do I contact them
  • Carolllin7 Apr 17, 2008
    My washing machine has a broken coupler or transmission, I think. The electric motor is working because the pump work. There is a noise but the agitator doesn't work. Is there a way to fix this without calling a professional?
  • jael08 May 30, 2008
    My model 70 is a good washer, and 2 days ago it stop spinning. I looked underneath to see what the problem is and there are to many part that turn that could be the problem. The water drains fine, just no spinning!! Could you please help me?
    sincerely,
    Jason Shane
  • platnumenyce May 31, 2008
    doesnt aggiate or spin.... seems as if clutch is stuck!!!!
  • petek1 May 04, 2009
    motor coupling is broken
    best way to disassemble
  • shancr2 Nov 30, 2009
    My washer does not drain. any help will be greatly appreciated.
  • Anonymous Mar 22, 2014
    old model about 10 years old
  • Anonymous Aug 14, 2019
    After it fills the water it will not agitate or spin at all the buzzer sound comes
  • 290 Answers
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Posted on Nov 13, 2007
  • Michael  Lindley
    Michael Lindley Nov 13, 2007
    Here are the steps for the most common of the 70 series washers.
    Remove the two screws that hold the console to the cabinet and flip the console back.
    Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
    Remove the clips holding the water pump and move it to the side.
    Unplug the wires from the motor and remove the clips holding it.
    You will see the motor coupler.
    Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
  • Michael  Lindley
    The screws that hold the console are under the trim pieces at the front edges of the console. They pop off.
I have a Kenmore washer model 110.20702990
I will go thru wash cycles but then stops and will not restart. I can move the timer but it still will not start other than agitate. Is there a simple fix for it?
Posted on Apr 08, 2008
Kenmore 70 Series Heavy Duty Plus Style Master 902202 Rev F Washing machine
failed to drain water; it's running & spinning in the Prewash Mode and keeps running
thru the washing cycle till it stops at the OFF stage.It does not stop at the end of
the Prewash stage now.Water is not draining.
Posted on Nov 02, 2008
    New Friend:
I have a Kenmore 70 Series washing machine. Wife says it smelt like something was burning yesterday when she had it running and she shut it off. Towels were still wet when I arrived on the scene, so I assume it didn't spin prior to her shutting it off.
Serial # CD0897639, Model# 92273100
Frank
Dryden, Michigan
Posted on Oct 27, 2009
My washer does not spin or drain please help me
Posted on Sep 16, 2010
If your Kenmore 70 series is making a grinding noise, filling and draining but not spinning or agitating, its usually as simple as a belt. If you pull it out, remove the back panel and see the belt just sitting there, that will be your confirmation. Sears, Home Depot, Osh, or Lowe's should have the part...
Posted on Jan 24, 2009
  • pastorkir40 Aug 09, 2011
    There are no belts, it is a direct drive. The coupling between the motor and gearcase seems to be in good condition. Can the gear box be repaired or does it need to be replaced?
I start my washer and it keeps running it wont go through the cycle change unless I force it to. If I turn it on and off and on and off again it will start. What could be the problem?
Posted on Apr 20, 2008
    New Friend:
My washer Kenmore 70 series is making a grinding noise, filling and draining but not spinning or but the agitating is soooooo slow. I looks like it wants to move.. can i fix this myself.
Posted on Feb 06, 2013
  • Melissa Bolanis Feb 06, 2013
    my washer Kenmore 70 series is making a grinding noise, filling and draining but not spinning or but the agitating is soooooo slow. I looks like it wants to move.. can i fix this myself.
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
I have a kenmore 70 series washer,the machine won't spin. I hear the clutch but it's not engaging. The pump to remove the water seems to be operating but the tub just won't spin and makes a loud noise.
The loud noise (sounds like rattling or grinding) is the motor coupler. It's between the motor and the transmission. This part takes the place of the belt, and costs about $20.00.
Mar 31, 2008 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
15,517 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
