There is no Blue screen disable option on the camera.
Since the blue screen caused by the video heads, try to clean it up by running a cleaning cassette.
The cleaning cassette helps only for minor clogs of the Drum(video heads)
Hello, well you will find if you use Windows Vista/Win 7 no drivers for Sony cameras are loaded, none as far as I am aware are made. But if you use Firewire cable as I do you wont need drivers, BUT make sure your camera is connected to PC via Fire Wire before you turn PC on, as it wont work if you get this wrong. Bye David
this error pertains to one of the reels (the thing that turns the tape)is malfunctioning.so most likely you'll be having issues w/recording,playing,fast forwarding or rewinding the tape.you can try RESET (press the reset button located inside and beside the eject button in the tape compartment cover, while cam is on).if it doesn't work try POWER RESET (turn cam off,remove the batt,make sure the ac adaptor is not connected.turn power switch to camera or player, and leave w/o power for at least a minute.turn power switch back to off and reinsert batt.check if working).if still you get the error,repair might be needed.hope this helps.thanks:)
