Question about Mercury Marine 4hp & 6hp Stroke Outboards Outboard, 55lb., 15" Shaft
How to find model number on mariner outboard 4hp 2stroke engine
    Sergeant:
  • 331 Answers
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Posted on Mar 01, 2015
SOURCE:
Mariner 8 hp outboard serial number 0G156538 -- what year is this engine?
Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly
Hey Peter, try these guys.
https://www.marineengine.com/
Jul 03, 2017 | HP Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
How do i replace shift lever on a mercury 6hp 4 stroke
shift lever has a bolt in it and shift rod you need to remove powerhead complete to access also remove gearbox !
May 04, 2014 | Mercury Marine 4hp & 6hp Stroke Outboards...
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
We have a mercury 60 2stroke outboard engine and nothing happens when you turn the key to start it
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
May 09, 2010 | Raymarine St6002 Smartpilot Hydraulic...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Mariner 4hp outboard can't get engine off casing
the drive shaft goes down through the water pump impeller and I suspect that the problem will be in the pump
the impeller is rubber and if run dry will melt the rubber into the housing and bind up the shaft
Brute force is a last resort so get all the information you can from a service dealer mechanic
Nov 12, 2017 | 2004 Mercury Mariner
Mercury Marine 4hp & 6hp Stroke Outboards Outboard, 55lb., 15" Shaft Logo
759 people viewed this question
Top Mercury Marine Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
johnny bonacci
johnny bonacci
Are you a Mercury Marine Boating Expert? Answer questions, earn points and help others
