GE Profile WPRE6100G Top Load Washer Logo
A
Anonymous Posted on Feb 27, 2015
My machine works, but the will not light up - GE Profile WPRE6100G Top Load Washer
Ken Wieczorek
Level 2:
Sergeant:
  • GE Expert 451 Answers
  • Posted on Feb 27, 2015
Ken Wieczorek
GE Expert
Level 2:
Sergeant:
Answers
451
Questions
0
Helped
228183
Points
825
Bad connection on led board may need new board
FIMER X164 ARC small welding machine yellow light failureyellow light turns on
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiaguOEt66DAxVurYkEHXr6C4QQFnoECBsQAQ&url=https%3A%2F%2Fmaker.pro%2Fforums%2Fthreads%2Ffimer-x164-arc-small-welding-machine-yellow-light-failure-yellow-light-turns-on.297568%2F&usg=AOvVaw2jwzGb4J6K4_3Xm5MoEBr0&opi=89978449
Sewing machine sews only when the light is on
sounds like there is a short somewhere in the machine and needs to be checked
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
After cleaning Artista 170 my sewing light is not on
if the light was working before it was took to the shop & now it's not working
I agree call them & tell them
Light doesnt work,where is the vuse
If the machine works but the light does not you will need to change a bulb, if the machine and light does not work try the fuse in the plug.
3helpful
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
1helpful
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Red light will not go off and the machine does not work
try letting vinager and water sit in it for a couple of hours then rinse
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Indesit 123
PLUG THE MACHINE OUT FOR 40 SECONDS THEN TRY AGAIN THIS WORKED FOR ME,IF THIS DOES NOT WORK THE MACHINE HAS TO BE REPAIRED BY A TECHNICHIAN
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
