SOURCE: incoming call number barring
I have been told this not possible on nokia 6300 without buying a package which I don't need as I will just ignore call from this particular caller.
Thanks any way for your help.
Regards,
Peter.
SOURCE: unbarr international calls
The only solution to your problem that comes to my mind is to get your firmware upgraded from Nokia Care. And in future remember the password, or atleast write it down some safe place.
SOURCE: im trying to prevent my phone nokia e71 from
Get the barring code from your network provider. You can call the customer care line and request for this.
Good Luck
SOURCE: i need a call barring code for Nokia 5800
The code is 0000 or 1234 its a default code for all models try it definitely you can have a solution.
SOURCE: My mobile nokia n72 i need barring password from
call barring password
This is the code you need to change call barring settings that are stored on the network. The default code is set by the network (0000 or 1919 for Vodafone,1111 for Orange,0000 for O2)). You can change it if you like, but make sure you don't forget the new code.
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
