Alpine PKG-RSE2 Car DVD Player Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How cani change the region code
How can i change the region code from 1 to 4
Marvin
Level 3:
Top Expert:
  • Alpine Master 85,242 Answers
  • Posted on Jul 08, 2009
Marvin
Alpine Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056948
Points
266281
This is a "hack" procedure, none yet exists for your deck, check back in a few months.
1helpful
4answers
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
1helpful
2answers
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
2answers
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD Player
Let me know if this Apple data helps!
Regards,
-Mactechtrainer
2answers
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
How can i change regional code on panasonic sc-bt207
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__yhg6
2answers
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
1helpful
2answers
Change DVD Region Code
Regards, Jay__okj4
1helpful
2answers
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
3answers
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
