SOURCE: Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
SOURCE: misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
SOURCE: Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
SOURCE: Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Testimonial: "Thank you so much for the help , I have tried the Bypass Tray but still getting the jam code."
