I want to use this P/S for a project and I can't turn it on outside of the PC. It isn't a ATX standard.
Pin
Name
Color
Description
3.3V
Orange
+3.3 VDC
3.3V
Orange
+3.3 VDC
COM
Black
Ground
5V
Red
+5 VDC
5
COM
Black
Ground
6
5V
Red
+5 VDC
7
COM
Black
Ground
8
PWR_OK
Gray
Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok)
9
5VSB
Purple
+5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec)
10
12V
Yellow
+12 VDC
11
12V
Yellow
+12 VDC
12
3.3V
Orange
+3.3 VDC
13
3.3V
Orange
+3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V).
14
-12V
Blue
-12 VDC
15
COM
Black
Ground
16
/PS_ON
Green
Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
17
COM
Black
Ground
18
COM
Black
Ground
19
COM
Black
Ground
20
-5V
White
-5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units)
21
+5V
Red
+5 VDC
22
+5V
Red
+5 VDC
23
+5V
Red
+5 VDC
24
COM
Black
Ground
/PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
SOURCE: please help me about my power supply it is compaq
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
SOURCE: anyone can give me a circiut diagram for my power supply
REPLACEMENTS ARE HERE..http://www.calhountech.com/search/index.php?part=PS-7231-6CF...OR TRY CONTACTING COMPAQ SUPPORT AT....http://h18000.www1.hp.com/cpq-country/cpq_support.html.RICHARDM69
SOURCE: A NEW DELL OMNIPLEX GX 620 POWER SUPPLY WILL NOT
R U sure it turns on, off the board? OK perhaps current level is set too low? not all connections are right?
SOURCE: can i change the power supply of my optiplex gx280
yes, Opti GX280 is a standard ATX powersupply
SOURCE: Is the power supply for a ThinkCentre S51 8172 a
No, it's a custom size one. You need to replace it with an identical one.
