you can save them to computer via usb, any new photos will store to the memory card.
unaware that you can transfer between device and card as the processor probably cannot handle the data of read and write at the same time.
The C613 works with MMC and SD cards. Make sure you're not trying to use an SDHC card. MMC and SD cards max out at 2GB in size.
You can download Kodak software from http://support.en.kodak.com/app/answers/list/c/890
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
When the memory card is in the camera, you see the card contents, not the internal memory. Take the card out, then delete all the photos you can find. The camera needs space on the internal memory to work, even if the memory card is empty.
Hook up your cable to the camera and the computer.
Turn the camera on.
turn off whatever pops up.
Look under my computer.
you will see the camera as another drive
click and drag.
Maybe you should try switching memory cards. Maybe the one you have is not good. If that doesn't work, take it to the place were you got the camera and explain what the problem is. That should help. Toodles
Make sure the card is fully pushed in; otherwise it could be the reader. You could try to insert the card into an external card reader connected to a PC. If it is recognized by windows, click "format". If that works put the card back into the camera. If it is now recognized, go to "menu" and format again with the camera. If the card is not recognized, your internal card reader seems to be faulty.
Just sorted similar problem on my camera. For some reason, the memory
card option had reset itself to Internal only. It needs to be on Auto
to take the external card into account. Press on Menu button, scroll
down to Memory and select Auto. Hope it works for you too
Just sorted similar problem on my camera. For some reason, the memory card option had reset itself to Internal only. It needs to be on Auto to take the external card into account. Press on Menu button, scroll down to Memory and select Auto. Hope it works for you too.
