Refrigerators Logo
J
Justin Carey Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I blew the fuse on the motherboard of a GE Adora Refrigerator and I need to fix it how do I repair it and install the new fuse
Blown Fuse on Motherboard on GE Adora Fridge. It was a little black so I thought it might have been blown but blew it checking it and now fridge wont run at all. I need to get this fixed asap
Frederick Electrick
Level 3:
Master:
  • Master 350 Answers
  • Posted on Feb 26, 2015
Frederick Electrick
Master
Level 3:
Master:
Answers
350
Questions
Helped
107177
Points
1344
Definitely need to change fuse , Un Plug the fridge First,
a Google search can tell you location and size of the fuse....
While changing the light bulb under the unit, the wire connected to the light bulb holder touched the metal housing and totally blew out the microwave so it doesn't work.
normally there is a glass fuse in the circuit where the power comes in
check that fuse/ replace if necessary
As silly as it sounds --turn the equipment of at the wall before you work on it as it might have been you that blew and not the fuse
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
1helpful
Hi I have a ge adora dryer that won't heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 26, 2011 • GE Dryers
Fuse blew...I think
You will have to investigate to find out if you have blown an internal fuse. Try and trace the wires and see where they end up . If you can get your unit up and running again, insulate the wires and make enquiries as to what they are for from where you purchased it.
95 toyota carmy fuse has blown fuse in the car. when i was installing a new cd player wires touched and the clock light blew where should look for the blown fuse
under the dashboard its probably a 15 amp fuse . there should be a diagram on the fuse box that says what is what .it probably also blew out the cig. lighter ... good luck
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
4helpful
4answers
Dometic RM2852 will not turn on
The dometic recall requires the installation of a thermal fuse from the DC terminal block to the igniter,  Originally it was a solid wire connection, and the recall replaced this wire with a thermal fuse imbedded.  On my unit the installer placed the fused wire too close to the burner sheet metal and, viola, the fuse blew (being thermal).  Camping World found the problem in 5 minutes and repaired it in another 10 minutes. $107.00.
Fisher & paykel gwl11 washing machine motherboard fuse blown
Maybe the pump got jammed and stalled and blew the fuse.
Top Refrigerators Experts
vince
Johnny 1000
